tv adjustment..i know!? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2005, 07:30 PM
pink63impala's Avatar
Last journal entry: my 63
ok i know its been posted before.but, i need some help adjusting my t.v. cable on my 700r4.
ive read to push the button all the way in, then pull the throttle wot.i done this but it doesnt pull the slider back out any.am i supposede to hold the button in while doing this?or is mine stuck or what?i tried to unhook it from the carb and pull it,but it doesnt come out that way either?..im running a holly 750 daul line single pump carb and have the holley bracket that bolts to the carb and holds the cable, and also have the bracket that bolts to the carb to correct the geometry of the swing.
any help or sugestions would be great.starting to get fed up with it!!
Old 02-19-2005, 11:34 PM
This gets fun. I have to assume you have a factory cable.
FIRST: Make sure that the carb is fully open when your foot is on the floor. this is very important. Do nothing until this is correct.
Now, with the carb at WOT, the TV cable must be fully pulled out of the cable housing. The adjustment on the cable will allow only about 3/4" of change. Carb at WOT and cable attached to carb, grab the cable ferrule (the little achor on the end of the cable). Use good pliers! Pull on the cable to see if you can extend the cable further. If so, adjust cable by pushing the lock release tab and shove the cable housing rearward. If you still have too much cable slack, try to measure the distance the ferrule moves forward. Knowing this, you will have to remount the cable achor bracket, or you can slip a short piece of 1/4" brake line over the ferrule end, lightly crimp to keep it there and readjust the cable. The cable MUST NOT MOVE forward when you tug on it (ferrule end) when the carb is at WOT. If the cable is tight at WOT, then the TV valve in the valve body will be bottomed (full detent) when you go to WOT. This is the corrrect and desired result.
Also, be sure to observe the cable bracket when the throttle is opened. It CANNOT FLEX!! Flexing here WILL distort your adjustment and proper cable operation.
Hope this is clear as mud
Old 02-20-2005, 05:12 AM
ill try this and see what i got.but is the slider/adjuster supposed to come out any when its wot?
Old 03-09-2005, 08:50 PM
any other info?
Old 03-09-2005, 09:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by pink63impala
any other info?
Chazmac gave you all the info.
what is the problem?
you do not understand?
The tranny is shifting wrong?
Old 03-10-2005, 10:34 AM
not sure if i completly understand. when i pull the throttle wot. is the slider suppoesed to pull out a little bit? or do i not have enuff pull on it or what?themn that rebuilt it, said it should pull out to a piont he showed me.but it doesnt .i havent really drove it about 3 or 4 miles to tell a whole lot about it, and the first mile or two was slowly to make it back home cause i forgot to tighten the center bearing!
but i think i got it set to where when it changes from 1-2, i can mash it to the floor and it will kick down to 1.aslo it changes from 4 to 3 when im running normal speed and floor it
having a problem with the tv in my car..any tv repair men on here? RodFather Hotrodders' Lounge 0 01-04-2005 08:42 AM
Direct TV - Anyone have it? Do you like it? 6567GTO Hotrodders' Lounge 20 10-03-2003 01:32 PM
lifter adjustment Deadtemple Engine 1 09-20-2003 05:57 PM
TV cable issues on 200r4 Roy_67_SS350 Transmission - Rearend 2 09-15-2003 11:55 PM
700r4 TV CABLE installation or calibration ss crazy Transmission - Rearend 2 04-07-2003 08:20 AM
