-   -   TV adjustment with lokar cable on 700R4 (http://www.hotrodders.com/forum/tv-adjustment-lokar-cable-700r4-167088.html)
jjlabinski 10-21-2009 01:06 PM
Hi Folks.....new to your forum.
I have a street machine ...fuel injected chevy 350 with 700r4 3000 stall converter, B&M overdrive spool so the trany doesnt kick down at 3/4 throttle and the gil younger shift kit with corvette servos.
I am using the lokar TV cable and I cant seem to get it to shift properly.
Can anyone offer some advice?
thank you
Jeff
302 Z28 10-21-2009 03:38 PM
What is your geometry? It is very important that you have the correct bracket geometry where the cable attaches to your injection. Other than that the Lokar cable adjusts just like any other. Open your throttle all the way pull the cable out all the way and adjust the cable until it matches the WOT position. Then close the throttle and see if the unextended cable position matches the closed throttle position. Some pre-load on the cable is desired at idle position.
Have you visited the 700R4.com web site for instruction?
Vince
jjlabinski 10-21-2009 05:11 PM
lokar cable
Thank you for the reply.
The way I have it set now is I pulled on the TV cable until it wouldn't move any more at full throttle. I dont know if that positions the valve in the proper position in the closed throttle position.
Is there a preferred method of verifying the geometry?
how much pre load should be on the cable at closed throttle and how does one measure that?
thank you
Jeff
302 Z28 10-21-2009 06:32 PM
The idle position is usually set with a pressure gage attached to the trans. You pull it out just a little until you see the pressure rise and that is the idle position. Without the pressure gage just pull it out about 3/16" of an inch.
The geometry at the throttle has to be correct, that is to say that the ratio of the cable travel has to be correct for the given throttle movement. A lot of adjustment to shift points and overall feel can be made with an adjustable throttle crank.
What injection system do you have?
Be advised that an improperly adjusted TV cable can ruin the trans in a very short time :pain: .
Vince
C-10 10-22-2009 12:25 AM
The pressure is a very good indicator of condition and trouble shooting.
Here is a wordy write-up on the TH700R4 throttle valve.
http://www.hotrodders.com/gallery/data/500/700R4-1.jpg
http://www.hotrodders.com/gallery/data/500/700R4-2.jpg
SSedan64 10-22-2009 06:21 AM
This is for the BTO kit but, has some Info, Step #4> http://www.tvmadeez.com/tvcable_inst...aidedcable.php
And here. >> http://www.tvmadeez.com/tvcable_inst...dedadjust.html
jjlabinski 10-25-2009 05:32 PM
Thanks for the pointers.
Where do I connect the pressure gage and what range should the gage be?
thx
Jeff
SSedan64 10-25-2009 10:35 PM
thx
Jeff
Check here>> http://www.tvmadeez.com/pressure_test/index.php
Todd
