TV Boost and low/rev boost valves. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2006, 07:10 PM
Drewnashty's Avatar
sitis nam accelero
When increasing the diameter of the TV boost and low rev boost valves does it drop line pressure at lower speeds and hamper low speed performance?
Old 06-06-2006, 08:21 PM
Drewnashty's Avatar
sitis nam accelero
I'm just thinking that at lower speeds isn't there less pressure in the lines? So then with larger diameter valves wouldn't that decrease velocity and pressure in the line at low speeds decreasing shift speeds and apply force? Or am I confused?
Old 06-06-2006, 08:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by Drewnashty
Or am I confused?
yep ........
