TV bracket for Vortec Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2003, 03:21 PM
MI2600's Avatar
Member# 3287
I think I've finally found an answer to my TV cable problem. I've got an aftermarket bracket that bolts on the back of the carb. The trans is a 200R4. Intake and carb are Edelbrock. The throttle cable is ok, but the TV cable is about 4-5" short. Complicating everything are the Vortec heads which have a different pattern.
According to Edelbrock, their bracket # 8032 is the answer. Got one on order...let you know.
Old 09-30-2003, 08:16 PM
MI2600's Avatar
Member# 3287
Forget the Edelbrock bracket. I mounted it tonight. The TV cable is still too far from the carb and the throttle cable is mounted such an angle that it rubs on the carb (Performer) fast idle linkage. Boo!
Anybody running Vortec heads with an Edelbrock and a 200R4?
Old 11-01-2003, 10:49 PM
root's Avatar
New Member
TV cable
Hey wazup,I am running a 350 vortec heads, Edelbrock manifold and 1406 in my 95 Toyota 4x4,I am also running a Bowtie overdrive 700r4 and there TV system,works great.Call Steve at Bowtie overdrive and he will set you up.760-947-5240,hope this will help.
