TV Cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2003, 06:54 PM
MI2600's Avatar
Member# 3287
TV Cable
I didn't want to ask a question in the middle of Destructo's thread.
Are the GM 200 and 200R4 TV cables the same? I've got a 200R4 linked to a SBC with an Edelbrock carb. I've got the aftermarket bracket that mounts the throttle and TV cables on the rear flange of the carb. The cable is the one for the former 200 trans. There is a 4-5" gap between the end of the cable and the carb stud. Was/is the 200R4 longer?
Old 09-05-2003, 06:58 PM
tnsmith10's Avatar
when will it rain???
t.v. cable
yes it is., and positioned farther back then the 200c. u should be able to buy a replacement cable for it about anywhere, but a local trans shop might be of better assistance. gl
Old 09-05-2003, 07:26 PM
i need a liitle help
i need a original M-21 close-ratio tranny and original set of
3.90's from a 67 GTO for MY 67 GTO. does anyone know were
i could find them.
