TV Cable Adjust 200r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2017, 07:32 AM
I have a 1984 Buick Regal Turbo that has an issue with premature gear shifts. At light throttle, seems like I'm thru 3rd gear by 25 mph, and at WOT it shifts around 4000.
I tried to do the TV Cable Adjustment by pushing in the button and pulling the cable back forward the firewall. However I find that it is already as far back as it will go. I confirmed this by then pushing the cable forward and it will ratchet forward 5 or 6 clicks. If I understand the procedure, that is tight as it will go.
The cable looks pretty new, so it doesn't seem like that it is simply a cable that was stretched after 30 years of use.
Any suggestions on what else could be wrong causing the early tranny shifts, or how I can tighten up the cable further??
Old 06-19-2017, 11:16 AM
Reset your cable to factory specs., then with the hood open, motor off, have a friend push the throttle to the floor slowly and see if your cable bracket is loose or bending. I have a ridged system and it can't move. If it given any at all, you need to correct it immediately.
Old 06-19-2017, 09:36 PM
64nailhead's Avatar
Check the governor springs. One will be missing or dislodged. That's my guess and I'm sticking to it.
p.s. - all TV cable adjustments on an older/original transmission should be done with a line pressure gauge. The factory adjustment will work fine as long as you have correct TV spring tension and length. The line pressure gauge eliminates all guessing and trans damage.
Old 06-20-2017, 07:54 AM
Ok. I'll get a gauge, but assuming I find out the pressure is low, how does that help me adjust the TV cable (which appears to be maxed out already) or know if the problem is with governor as you are suspecting?
Old 06-20-2017, 01:58 PM
64nailhead's Avatar
To find out if the TV is maxed out pull your throttle arm to WOT and thene see if you can pull the TV cable any further. This will require some reasonable effort, but like your trying squat lift 300lbs.
Are you familiar with what your pressure should be? Without sounding too elementary, you want the pressure to rise just as you move the accelerator pedal so that the transmission sees a pressure rise. This is measured while driving. At WOT you should see a minimum of 175lbs on a stock pump setup. Check the pressures in all gears as well while sitting in the driveway and record all.
The big killer of all 200's is too low of line pressure. They will work like normal, for a short period, with a misadjusted TV cable, but again, for a short period.
If it is too low, then either adjust it to spec or plan a rebuild including the pump. If your fluid is in good condition in terms of color and smell, then I'd guess you'll only need an adjustment if the pressure is too low. If you fluid is wiped out, then there's your sign unfortunately. If your pressure is good, then head for the governor springs. It could be something else, but doubtful IMO.
Old 06-22-2017, 07:43 PM
Just curious, did you find the problem?
Old 06-23-2017, 09:29 AM
I did the WOT test and confirmed the TV Cable does not pull out any further.
I have not yet checked the pressure yet, but I am going to go with what 64nailhead indicated and say this is a govenernor problem.
I am suspecting this entire tranny has been replaced. I know for a fact that it had the wrong Speed-o gears. So the early shifting would be consistent with a tranny from a different car. I think these 200-r4's were attached to an Olds 307 that shifted much earlier than the Turbo Regals.
I've seen some places selling governors for the Turbo regals, but if I understand correctly, unless I find a matching valve body the shift points still wont be right.
200r4 tv cable adjustments omaha kid 34 Transmission - Rearend 0 04-26-2012 10:13 PM
200R4 TV cable Dav3 Transmission - Rearend 9 09-20-2008 07:58 PM
200r4 tv cable cartune7 Transmission - Rearend 1 03-22-2005 07:49 AM
how to adjust a tv cable jo5hi3 Transmission - Rearend 9 10-02-2004 04:51 PM
how to adjust the gear cable stoney 81ta Transmission - Rearend 7 12-28-2003 10:04 AM
