Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TV cable adjustment on 700R4
Old 03-26-2012, 05:19 PM
LATECH's Avatar
LATECH LATECH is offline
Originally Posted by topwrench
Thanks L.A.
That Le Mans is looking good
How do I know if its damaged?
And can I decrease the RPM at which its shifting by lossening up the cable some
Hey thanks top wrench.I love my poncho
Best to get the setup correct and then drive it to see how she acts, dont jump the gun. You could pull the pan to look for any metal or anything else in it to satisfy your curiousity.If it has metal in it you may want to tear it down to see what got munched, otherwise after the TV Cable geometry is corrected, just drive it
Shift points should be manipulated by the governor springs and weights.
check this out here:
http://www.transmissioncenter.com
go to tech support for the 700 and it will have a list of good info. The site is the bomb for all the info you could want
