Went with a performance rebuild, its in the shop now. Didn't do the valve body just yet will hook up a pressure gauge when I get it back and make sure I have the correct pressure readings when its at idle and shifting.
http://www.tvmadeez.com/press_gauge/pressgauge.html
http://www.tvmadeez.com/pressure_test/index.html
topwrench if you do this pressure test you will be able to tell if the TV is setup correctly.
