TV cable adjustment on 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2012, 07:05 PM
topwrench's Avatar
Last journal entry: fish carb
I have a 700r4 behind my 496 67 Camaro,Ford 9 inch rear 3.73:1 gear ratio.
When I first took this car out the trans would shift way too early,so I tightened up the cable on the carb,just got back from a road test.
Car is extremely fast now!!
My question is am I gonna hurt this trans?
Its shifting right at 4000 rpms right now,like BANG,really hard.
So what is the correct method for adjusting the TV cable and can I leave it like it is
Thanks in advance
Al
Old 03-25-2012, 07:33 PM
LATECH's Avatar
The geometry for the linkage of a 700r4 is critical to performance and long life. You actually may have allready damaged it if the proper geometry is not designed into the linkage at the carb.
Here is a picture of the correct geometry, provided by art carr.and my last photo bump of my 64
ID:	64323   Click image for larger version
Old 03-26-2012, 06:47 AM
topwrench's Avatar
Thanks L.A.
That Le Mans is looking good
How do I know if its damaged?
And can I decrease the RPM at which its shifting by lossening up the cable some
Old 03-26-2012, 07:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks in advance
Al
Also check out linkage angle/travel requirements HERE from transmission guru jakeshoe.
OEM TV cable function HERE.
Q-jet and many other carb Installation Guides (on left side of page) on THIS page, instructions on left side for different carbs.
Hotrodders forum thread HERE.
Old 03-26-2012, 02:22 PM
327NUT's Avatar
DO NOT drive the car at all until you have the tv cable adjusted PROPERLY! You can and probably already have ruined the trans by now. Go to www.bowtieoverdrives.com and look up their info on adjusting it.
Old 03-26-2012, 06:19 PM
LATECH's Avatar
Thanks L.A.
Hey thanks top wrench.I love my poncho
Best to get the setup correct and then drive it to see how she acts, dont jump the gun. You could pull the pan to look for any metal or anything else in it to satisfy your curiousity.If it has metal in it you may want to tear it down to see what got munched, otherwise after the TV Cable geometry is corrected, just drive it
Shift points should be manipulated by the governor springs and weights.
check this out here:
http://www.transmissioncenter.com
go to tech support for the 700 and it will have a list of good info. The site is the bomb for all the info you could want
Old 03-26-2012, 06:45 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Anyone ever use one of these?
Constant Pressure Valve Bodies
http://www.jegs.com/i/TCI/890/376020/10002/-1
I just pulled my 700r4 out of my Vette because the TV was not right when I got the car.
I fixed it but it was too late and last week I lost all forward gears.
Going to have it rebuilt and will ask the builder what he thinks about the CPVB. I like the fact that you don't have to rely on the TV to regulate pressure, it is only used for shift points.
Old 03-28-2012, 10:43 AM
SSedan64's Avatar
I wouldn't recommend the CPVB for a daily driver. The Pump is running at constant Max. pressure when using the CPVB. This puts a heavy load on the Pump, premature wear, also the 13-Vane Rotor that most use is weaker than the 7 & 10 Vane, more prone to breaking.
Old 03-29-2012, 04:11 AM
Went with a performance rebuild, its in the shop now. Didn't do the valve body just yet will hook up a pressure gauge when I get it back and make sure I have the correct pressure readings when its at idle and shifting.
http://www.tvmadeez.com/press_gauge/pressgauge.html
http://www.tvmadeez.com/pressure_test/index.html
topwrench if you do this pressure test you will be able to tell if the TV is setup correctly.
Old 04-01-2012, 10:37 PM
topwrench's Avatar
Thanks guys!
Thanks for all your help,I think Ive got it straight now!
Old 07-27-2012, 04:17 AM
unless you have the tv cable absurdly out of adjustment you will not damage trans. and anyone who tells you otherwise has had 700r4's that were ready to puke. tightening tension on tv cable will make it shift later , too loose will make it shift too early. having the tv too tight isnt harmful, its annoying. it boosts line pressure. same thing a later model transmission does when it failsafes. a late model transmission does this to prevent any further damage and to firm up shifts. generally speaking 1st to second shift should be between 12 and 14 mph at normal throttle( grocery getting throttle). Ive had pretty decent install luck and gotten close by bringing linkage to full throttle with engine shut of and allowing 1/4 to 3/8's deflection on the cable. that will give you a place to start
Old 10-04-2012, 12:14 AM
Excellent sight ........I just read through the whole thing. Anything you ever need to know about this trans. or TV cable setting and testing is there. I,ll be needing it when I get to my engine and trans install. THANKS
Gary Hooten
2004R /700R4 TV cable adjustment 72bluemalibu Engine 6 11-23-2010 10:42 AM
TV cable adjustment? steve40th Transmission - Rearend 4 03-13-2010 09:25 PM
TV adjustment with lokar cable on 700R4 jjlabinski Transmission - Rearend 7 10-25-2009 11:35 PM
TV Cable adjustment / WOT mad55chevy Transmission - Rearend 4 04-24-2005 07:16 PM
700r4 detent cable adjustment chrisf67 Transmission - Rearend 2 03-28-2003 05:48 PM
