TV Cable adjustment / WOT - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2005, 05:23 PM
mad55chevy's Avatar
cutouts and 7k shifts = cops
I run a th200-4r that is a fresh rebuild. I have setup the TV with a gage, and it shifts fine. Problem is, when I do WOT, the TV cable becomes so tight that it stops the throttle linkage from opening up all the way. I am at risk of bending the throttle plates, because the TV cable bottoms out before the throttle does.
I am using a Holley 850, and a Lokar throttle cable, and a stock GM TV setup. Does the TV need to be a 1:1 ratio, or can it be less, like 1:.75??
CJ
Old 04-23-2005, 11:16 PM
willys36@aol.com's Avatar
Wiki Edits: 21
The throw on the cam of your carb is not matched to the required throw of the TV valve on the tranny. Get a 200R4 TV cable adapter from Bowtie Overdrives and that will solve your problems.
Old 04-24-2005, 11:08 AM
Crosley's Avatar
Wiki Edits: 1659
this site may help you with the proper geometry
Old 04-24-2005, 01:26 PM
Wiki Edits: 21
That's why I buy BowTie bolt-on links!!!
Old 04-24-2005, 06:16 PM
mad55chevy's Avatar
I bought the whole setup from BTO, and all the accessories with it.
Thanks for the purple sage site, that was great reading!!
I'll get this figured out soon enough.
CJ
Any hints on setting a TV cable for a trans? Oreif Transmission - Rearend 3 11-14-2003 08:30 AM
a/t kickdown cable adjustment maddmaxx Engine 4 10-27-2003 08:04 AM
TV cable issues on 200r4 Roy_67_SS350 Transmission - Rearend 2 09-15-2003 11:55 PM
TV Cable MI2600 Transmission - Rearend 2 09-05-2003 06:26 PM
700r4 TV CABLE installation or calibration ss crazy Transmission - Rearend 2 04-07-2003 08:20 AM
