Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tv cable bracket
Old 07-31-2007, 02:33 AM
JeffB's Avatar
JeffB JeffB is offline
700r4
Take the advice as per above but whatever you do check out some of the websites for proper adjustment of the TV cable,if it's not correct the 700R4 will toast the 3-4 clutch pack in a heartbeat(probably what killed the other trans) after you set it manually I would take it to a Transmission shop and fine tune the adjustments using a pressure gauge .
