Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tv cable bracket
Old 07-31-2007, 06:37 AM
Not A T 25's Avatar
Not A T 25 Not A T 25 is offline
Takes Guts To Cut One Up
Originally Posted by JeffB
Take the advice as per above but whatever you do check out some of the websites for proper adjustment of the TV cable,if it's not correct the 700R4 will toast the 3-4 clutch pack in a heartbeat(probably what killed the other trans) after you set it manually I would take it to a Transmission shop and fine tune the adjustments using a pressure gauge .
I purchased a trans pressure gauge for around $35 the tap in port is very easy to get to and set them myself but then there were no trans shops locally. I have done it a couple of times since then when I have made intake changes not a bad investment.
Success is getting what you want but happyness is liking what you get.
