Hotrodders Bulletin Board > Tech Help> Transmission - Rearend
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 05-29-2008, 12:15 PM
Cousin_Joe Cousin_Joe is offline
TV cable geometry on a Holley carb
I just installed a 200-4R trans in my Impala. I have a Holley 600 that I bought the TV bracket & TV geometry corrector for (Holley parts). I've seen all the diagrams and read for hours on how to adjust the cable correctly. I believe I've done so, but I have a question. I've seen multiple diagrams that say 1/3 of the travel before 90° to the throttle shaft. My setup is much more like 1/2 before/after. Total travel seems real good, is the 1/3 travel really important?
  #2
Old 05-29-2008, 12:19 PM
Jmark's Avatar
Jmark Jmark is offline
Moving to the trans forum, hopefully, the trans guru's will help you out.
Old 05-29-2008, 01:25 PM
C-10's Avatar
C-10 C-10 is offline
Revolution Calling
Last journal entry: Poverty caps live on.
I'd hardly call myself a guru, but I can try and help.
You've probably seen the illustration below. If not, basically make sure your TV cable hookup is 1.125" below the centerline of your throttle shaft.
Also make sure that when the throttle is floored, the TV is at 'full pull'.
Size:  87.8 KB  Click image for larger version
Old 05-29-2008, 01:34 PM
Thanks, I have seen them. The cable to centerline distance is right on the 1.125 dimension, and I am at full pull @ WOT. It's just like that photo below where must of the arc is in front of the throttle centerline. The Holley setup I've got puts the arc further back. Of course, all the photo's I find are Q'jets or Edelbrock carbs, or tv-ez setups. I'm assuming it won't be a problem, or Holley wouldn't be selling a part, I have followed their install fully.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "TV cable geometry on a Holley carb"
ThreadThread StarterForumRepliesLast Post
Holley Carb. QuestioncrusherdbuzzEngine207-02-2006 04:25 PM
Holley carb has me at wit's endcool rockin daddyEngine2306-02-2005 03:38 PM
700r4 TV CABLE installation or calibrationss crazyTransmission - Rearend204-07-2003 09:20 AM
Need some pointers on Holley carbcrshrmn3Engine202-09-2003 12:22 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
