Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TV Cable Travel?
Old 06-24-2013, 08:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Link to various info that may help.
I was wondering about the bracket because the adjuster mounting point needs to be set correctly.
From Mad Dog:
Use the following procedure to determine if your ADJUSTER MOUNTING POINT is correct:
a. Push in the Adjust Tab and retract the Slider in the direction shown in Figure 3.
b. Without allowing the Slider to move, pull the cable until it stops and measure from the mounting bracket to the cable end.
c. Add 3/16" to this measurement and that will determine the ADJUSTER MOUNTING POINT distance at full throttle (WOT).
