Twin I Beam - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2011, 05:50 PM
Twin I Beam
I have been asked to build a rat truck using a 65 f 100 chassis and body. My first question is how do you lower a twin I beam Ford pick-up and can it be done gracefully. I am not up on ford suspension........pc
Old 11-07-2011, 06:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
They make a I-Beam drop kit, but the only other way i know of lowering the front is by using heat but they have to be done the correct way or they are toast JMO i would go with a I-Beam drop kit if i were you. IMHO
The guy's in the link should have just what you need.
http://www.djmsuspension.com/
Cole
Old 11-08-2011, 07:37 PM
cboy's Avatar
Last journal entry: Finished
There is one other option, but it would require a good deal of work. And that is to "Z" the frame at the front end of the truck.
Always learning...and sharing what I've learned.
Old 11-09-2011, 10:57 AM
Id ditch the twin beam and do a double A arm IFS
Old 11-09-2011, 05:33 PM
Twin I Beam
Thanks for the info, I think I will go with the IFS, I have done a lot those on other street rods. Thanks again.......pc
Old 11-13-2011, 09:44 AM
seniormaster's Avatar
I'd use ifs also, there are lowering spindles and i-beams for newer trucks, just thinking out loud.
twin i beam in hot rod blor Suspension - Brakes - Steering 35 03-17-2013 09:42 PM
twin i beam twin i beam Hotrodding Basics 2 03-17-2011 01:28 PM
twin i beam twin i beam Engine 5 03-17-2011 10:50 AM
Twin I beam spindles on a solid axle Chevrolet4x4s Suspension - Brakes - Steering 5 10-11-2008 09:41 PM
twin i beam chuck 11 Suspension - Brakes - Steering 2 06-12-2004 08:27 PM
