Twin I-beam Ford front axels used on street rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2012, 11:24 AM
Can the Ford twin I-beam front axels, if used on a street rod, be heated and dropped in the same way that the early Ford straight axels are dropped to lower ride heigths on Street Rods?
Old 11-21-2012, 12:54 PM
Irelands child's Avatar
Yes they can - but I strongly suggest that you do a site search. There are several folks that have tried these but with little lasting success. There are 3-4 threads you can look at for information -
Irelands child
Old 11-21-2012, 02:25 PM
Wiki Edits: 27
truck I beams
Cboy used a Ford pickup as his donor in his eBook, it was a lot of work. click on the eBook at the top of the page, also check out his other build posts.. lots of information.
Old 11-21-2012, 03:30 PM
Wiki Edits: 31
The pre '81 beams can be heated and bent. After '81, beams were cast and not forged and cannot be bent. I used the entire front frame from a 1994 Ford Ranger ( Twin I beam ) on my scratch built, rather than fabricate my own frame. It would have been tough to figure out the angles.
66 ford truck twin i beam lowering tech igotachevyor2 Suspension - Brakes - Steering 15 12-16-2011 08:45 AM
twin i beam twin i beam Hotrodding Basics 2 03-17-2011 01:28 PM
twin i beam twin i beam Engine 5 03-17-2011 10:50 AM
H-Beam vs. I-Beam Connecting Rods juiced66malibu Engine 2 10-26-2007 08:29 AM
Ford I-beam front axle willys36@aol.com Suspension - Brakes - Steering 7 10-10-2002 07:24 AM
