Make sure you are very accurate at mocking up the chassis ride height, and then putting the axles in at the proper angle to give you the static camber you want when done. Camber is directly related to ride height on a twin I-beam suspension and unless it is correct at the ride height you want, the only way to change it is bend the axles.
Install them so the caster is correct also.
Andy
