Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - twin i beam in hot rod
Old 03-06-2011, 12:22 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
The best arrangement you could come up with would be to use the longest beams you can find, and then build the inboard pivot mounts to get the overall axle width you want. That way camber change is minimal with suspension travel.
You WILL need more than 1 inch of travel. 2-3" bump travel is minimum, along with at least 1" of droop travel.
Andy
