Twin I beam spindles on a solid axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2008, 07:35 PM
Will twin I beam spindles on a solid axle? If they will it seems like it could be a low cost option for disc breaks.
Thanks
Shane
Old 10-11-2008, 05:01 AM
..... bump
Old 10-11-2008, 06:08 AM
I seriously doubt it
I believe that the angle of the kingpin is different ... and the size of the kingpin is different also.
Old 10-11-2008, 06:28 AM
cboy's Avatar
Last journal entry: Finished
Hey Shane,
Did you try to do a Google search for this question? I've never heard of it or seen it done but maybe one of the 4x4 or F-150 groups on the web has discussed it.
Always learning...and sharing what I've learned.
Old 10-11-2008, 06:46 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I have been looking at this and I think it could be done but it is not a backyard deal as I would need to make axle ends to accept the Ford spindles..That requires a lathe and bridgeport to machine those ends which would then be welded into a tube axle..
The next question is why?? the truck spindles are heavy and the replacement calipers and rotors are not all that much cheaper than what I can get in aftermarket early ford stuff..
Sam
Old 10-11-2008, 08:41 PM
I checked google but couldnt find anything,I was thinking that someone on here used them,maybe on an international axle?
Shane
4x4 axle conversion ttb to solid front axle. Jared Transmission - Rearend 6 11-07-2005 08:50 PM
Solid Axle fred56 Suspension - Brakes - Steering 6 08-07-2005 10:47 AM
hydraulic cams/lifters brian12c Engine 4 03-07-2005 08:46 PM
Solid cams vs Hydraulic cams, preference or power? killerformula Engine 17 02-03-2005 09:42 AM
Center link steering with solid axle ken47 Suspension - Brakes - Steering 0 01-22-2004 11:37 AM
