Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - twin turbo sbc 383 help
  #113 (permalink)
Old 07-13-2010, 04:58 PM
lmsport lmsport is offline
Originally Posted by bipolar_camaro
As bad*** as that sounds, Im dropping the turbo setup and leaving that for my smaller motors. Also you are not gaining 125hp off of 5 psi. At 5 psi of boost your only adding about 20-30% more hp off your initial block power at best. So say you got a 400 horse motor that you want to run 5 psi at, say your getting a 25% hp gain out of that 5 psi your hitting 500 horse now. Atmospheric pressure is 1 bar (14.7psi), so if you were to run 14.7 psi of boost you would have twice as much pressure in the chamber as compared to no boost, therefore your hp gain would be doubled. 400 horse turns into 800..
Thats why the most common psi used in boosting is 7-8, at 7-8 your getting a 50%+hp gain on a good build. At least thats how all my prior experiences in the past have been with import motors.
Nevermind. You need to stick to Honda's. Leave the TT383 to those of us with the smarts. VTEC rulez!
