Wow, I think we have found the long lost brothers of MuscleCarGal.
She was going to run E-85 at 15:1 compression for better mileage in a 305! Majorownage doesn't know how a cylinder head wall gets oiled. Surprised he missed that lesson in Nelson's tutorial. Then Bipolar is going to build his FIRST sbc build as a 1000 + HP twin turbo set up. The familly reunions must be a riot. |
Give me Fuel Give me Fire Give me that which i Desire.
Cole Last edited by eloc431962; 07-13-2010 at 04:05 PM. Reason: words in wrong order, Dee Dee Dee. |
Vortec heads are out. Get some Iron Eagles, 200irv, big chamber. 280rv cam is out, get a custom ground turbo cam from isky. No need to turn over 6500. Figure about 125hp per 5psi of boost up to 15psi, plus the hp of the engine without boost. You will need intercooler and maybe alcohol injection. |
On a 355 build or 383? When i took this motor apart it had a rv cam in it with flat top pistons. So if i cam it harder i would need to go inverted dome on the pistons? |
As bad*** as that sounds, Im dropping the turbo setup and leaving that for my smaller motors. Also you are not gaining 125hp off of 5 psi. At 5 psi of boost your only adding about 20-30% more hp off your initial block power at best. So say you got a 400 horse motor that you want to run 5 psi at, say your getting a 25% hp gain out of that 5 psi your hitting 500 horse now. Atmospheric pressure is 1 bar (14.7psi), so if you were to run 14.7 psi of boost you would have twice as much pressure in the chamber as compared to no boost, therefore your hp gain would be doubled. 400 horse turns into 800.. Thats why the most common psi used in boosting is 7-8, at 7-8 your getting a 50%+hp gain on a good build. At least thats how all my prior experiences in the past have been with import motors. |
Nevermind. You need to stick to Honda's. Leave the TT383 to those of us with the smarts. VTEC rulez! |
man why are you still talking about turbos and boost. i thought you made up your mind about building a good street rod engine.
or are you just on here messing around with people.??!!?? |
I was telling imsport i wasnt going with a turbo application. Im going to stick with the 355 on a $2k budget to see where that gets me. As for gaining 125hp per 5psi of boost, I would love to see it as i have yet to see a gain like that. If you could present me with dyno sheets that would be awesome. But as i said " my experiences in the past with import motors", being a 383 has a much larger bore I cant say its impossible because i havent built one yet. Im just basing my estimations off of what i have achieved in the past, but then again you also have to apply the turbo mapping and math to any motor you are wanting to turbo. |
Regarding whether or not to use an OEM 4-bolt SBC block or a converted 2-bolt block, I originally said: Quote:
Provide a link to this info. I looked and see nothing on it. BTW, I'm following this up by forwarding this BS to Nelson- just for grins. I think you have (yet again) f-ed up by mistaking a 400 OEM 4-bolt block and its supposed weaknesses for an OEM 350 block (two totally different castings, there DA), or have otherwise misrepresented Nelson- who I'd imagine would give you a bi-ch slap for that infraction- I know I would. For your viewing pleasure, I submit the following: ![]() 2-BOLT OEM BLOCK ![]() 4-BOLT OEM BLOCK ![]() 4-BOLT SPLAYED CAP OEM BLOCK Using Milodon Caps ![]() 4-BOLT SPLAYED CAP FULL WIDTH REGISTER BOW TIE BLOCK ![]() 4-BOLT SPLAYED CAP DART BLOCK Surely, even a know-nothing, google professor such as yourself can plainly see the difference in clamping area provided by a splayed cap conversion of a 2-bolt OEM block over a stock 2-bolt OEM block or a stock 4-bolt OEM block. You see junior, the whole idea here is to provide ACCURATE info. To do otherwise compromises this forum's credibility. And that's something I will not stand for from you. Too many guys have put too much work into this place to let someone like YOU soil it w/your misinformation. Consider yourself served. Last edited by cobalt327; 07-23-2010 at 10:27 AM. Reason: Add Bow Tie photo. |
I would figure what gas you are going to run your engine on and go from there.
Because your 1000hp build wasnt going to run on pumpgas - well not for long anyway. I did a 2 bolt mains 454 with cast crank, stock rods, a CompCams blower cam plus some TRW 7.6:1 blower pistons and fitted a 671 on top and then went flash with a set of second hand Bowtie alloy heads. Only ran about 6lbs and made 627 hp. Strangely, the bottom end never let me down but the used alloy heads did. I think twin turbos are a great idea, but if I were you I would start with a good block and get some forged internals - rods crank & pistons, and build up from there. You wont see 1000hp unless you spend serious money, but you can get a start point that you can lean on, and learn from there. All the best with your SBC learning experience |
The September edition of Car Craft has an article where they bought a couple eBay turbos and a surprisingly cheap pair of generic-fit stainless steel turbo headers (~$100). This formed the basis for an el Cheapo dual turbo SBC that was in a '55 Chevy shoebox gasser style drag car.
The results were less than spectacular but it DID run (7.20's @ 90 mph in the 1/8 or about 11.4 in the 1/4), and WAS cheap. By the end, it made about 600 RWHP on a dyno and cost less than $2K. Be aware though- little items like a Quick Fuel 850 CFM carb was simply "pulled from the CC carb pile"- so the actual cost is obviously a LOT higher than the number they quote. And the long block wasn't included, either. Before you get too excited, this only begins to tell the whole story, so I'd suggest you do some serious research before going out and buying a pair of T3/T4 hybrid internal wastegate turbos. |
| 383 stroker turbo questions | work_n_progress | Engine | 10 | 06-23-2011 09:55 PM |
| twin turbo setup/ nd advice | SlidingSidways | Engine | 14 | 10-30-2008 07:59 AM |
| twin turbo 86 IROC camaro | biggunn770 | Introduce Yourself | 2 | 02-22-2008 07:09 PM |
| .60 over 383 SBC Questions | Mustangsaly | Engine | 8 | 06-28-2005 12:18 PM |
| 85 camaro with 383 stroker with nitrous oxide or twin turbo? | camaro dan | Engine | 0 | 10-08-2002 06:18 PM |
