twin turbo sbc 383 help
Hi, Im new to the forums here... Anyways my father in law gave me a smoked 355 to tinker with (blown head gasket and 4 spun rod bearings). Well the problem is I have never built a muscle motor before, I was all about the imports. My first thought to do with this motor was just build a simple 383 since all the work to the block has already been done. Although after doing some research I want to mix the import and muscle into one motor, example being variable lifters wich from my understanding would basically make whatever heads I bolt to this beast act as vtec heads, I think that would be pretty cool... As far as the build I am lost. So what Im asking for is a parts list of what Ill need.. Also this motor will be going into an 89 iroc z with the tpi (port and polish of course).
I know I need 2.02 heads, brand ????? 3.75 forged crank, 5.7 or 6.0 rods? inverted dome pistons or flat top? I need some help here, I used to taking ka24's, sr20's, b16+18's, h2xa's and just slapping forged internals in them. Port and polishing the heads, high flow exhausts, and running 15-20 psi of boost through them. My goal for this build is 1000+ hp, with twin 68mm turbos running at 1 bar of boost (14.7)... |
Good luck w/that. |
That said, my opinion is that an OEM block will not cut it. Actually, I'd be surprised if there were ANY OEM parts involved, period- unless the length of the fuse was of little concern. |
So far what Ive put together is, Scat procomp light weight crank (6.0 rod) Dart 2.02/ 1.60 heads, 72 cc cumb chamber (to help lower compression for higher boost) Still need help building the parts list |
As I said I am looking for help on the build, so far all you are providing me with is frustration... |
Wow....
I don't think anyone is trying to frustrate you. What you're looking for is something that people here may not have much experience with. While your build is interesting, it's not something you can do without quite a lot of money (not to mention experience). Variable valve timing aside, building an SBC to take the boost levels you're looking for is going to require a very good builder and a lot of money. There is a reason professional racers will spend $20k or more on their engine. Building a 1000hp SBC may not be too hard, but building that same power level and having it be reliable is a whole new undertaking. It can be done. However, I agree with cobalt. If you're going to run that kind of boost and those power levels, IMO the OEM block isn't going to cut it. |
what does the specialized shop say about twin turbo'in a oem block?
Your experience is with very small bores, short strokes, very light rotating assemblies and very high revs. When you get into the dynamics of pressures in big bores vice small bores, you can see that the big bores require cylinder walls that will withstand the extremely high pressures generated. Then you have to think of containing the much more massive rotating assemblies that are going to have to rotate at a much higher rate to make the horsepower you are talking about. An OEM block just is not going to cut it. Don't care if it is a tired old early 70s, bore tool breaking block made in Mexico(???). You just can't rewrite the laws of physics and rules of metalurgy to achieve unrealistic goals. But go ahead and knock your self out.
Trees |
With a low compression ratio there is nothing holding me back from pushing 12 psi. A little more work is required to get my 15 I looking for but it can and has been done with retained reliability. Even with 10-12psi my projected hp at the crank is between 950-1010. I also have most of my parts list put together finally after many phone calls throughout the day. Even if it takes me a year to complete this project Im going to do it just to show what limits you can push a OEM sb to. Also its not like this car/motor is going to be race only (hence the VVT). Like I was always told; where there is a will, there is a way. Im not sure if you guys are telling me it cant be done because either you have tried and failed, seen others try, or just scared to attempt it? Im surprised out of everyone that has posted none of you have encouraged it, only shot the idea down. Isnt building motors about trial and error? |
| All times are GMT -6. The time now is 12:09 AM. |
