Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Twin Turbo SBC build, need help
  #25 (permalink)
Old 04-20-2012, 09:41 AM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Depending on your build skills you can build your own kit for less money. However, picking the right components and making it work together takes time and research...ALOT of it. I have done a couple of these one off's and they are tons of work. I would suggest getting a kit if you have deep pockets, dont have alot of time, alot of patience, and good fabrication skills. I can help with some build specs, but in the end you will have to do your own research to have any level of success tuning it and keeping it together.
