Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Twin Turbo SBC build, need help
Old 10-15-2005, 05:46 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Some $'s look off like the cam {look more like $600-$800 for the setup, ie cam, lifters, push rods, rockers, stud girdle} and $2k for headers seems high? But when you have your total multiply it by 1.50 {150%} to get the amount it will take to accomplish your goals.
I would look at building a 7.5-8:1 450 hp combo then use a turbo setup that will yeild about 25psi max boost {but you may only need 20}.
I would plan on using something besides a zz4 unless you plan to mud it and run little or no coolant.
