Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Twin Turbo SBC build, need help
Old 10-15-2005, 10:15 AM
revvin kevin revvin kevin is offline
If you're serious about doing research go to you can learn tons about turbos there, even chevys! Blow through carbs aren't all bad, if you can tune efi you can surely tune a carb. Will not be as expensive as stated if done correctly.
