twin turbo tranny info - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2012, 08:39 PM
Hello out there
I am in the process of a twin turbo 406 build and hoping to get around 900hp
Anyone built a 700r or 200r4 for this type of hp?
if so what parts were used thanks
Old 10-01-2012, 08:59 PM
Maybe Frank Cahall from Cahall Performance Transmissions in Delaware...he has a web site. I know for sure that he builds one of the strongest 4L60e's and is also a real good guy that you can talk to on the phone.
Old 10-02-2012, 08:03 AM
3 of the big players are
Lonnie at Extreme Automatics
Chris at CK Performance
Jake 'jakeshoe' at Jakes Performance
I know Jake just started doing 200-4r's again and he holds his to around 550ft lbs reliably.
Something to think about, you will go nuts with trying to set shift points in a 700r/200-4r. You really need something in the 4L60e or 4L80e family; that way you get more strength and the ability to program the shifts.
2 other names I'll throw out there:
RPM Transmissions
Finish Line Transmissions
Old 10-02-2012, 08:40 AM
SSedan64's Avatar
To build a 2004R or 700R4 to hold 900HP/TQ is going to cost as much or more than a 4L80E. The 4L80E will also be much more reliable at that power range. The 3 names AutoGear listed build great 80E trans & can also supply the controller if you don't want manual only shifts.
Most Pro builders suggest:
2004R - 800HP/TQ Max.
700R4 - 700HP/TQ Max.
Old 10-02-2012, 12:03 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I was in the same boat, and originally decided on a 700R4-after doing my Homework, I realized that it wouldn't live in my Car for long, so I went with a Stage IV 4L80E from Jake's (which will hopefully be delivered next week)-if I were you I would definitely consider something that can handle the Torque that you will be producing, unless you like to R&R your Transmission-
Old 10-02-2012, 12:15 PM
thanks guys i didnt like the 80s because of the weight but the programming of the shift etc sounds right on
I think that a 4l60e or 80e prob will be the trans that i use
thanks for all the info 35window let me know how yours turns out
laters
Old 11-06-2012, 11:49 PM
Just finished up the 4L80E build.Next i will throw it on the dyno
cant wait to see it perform
Twin Turbo's srwilson8074 Engine 11 02-02-2012 01:45 PM
T3 twin turbo 1967chevelle454 Engine 0 02-04-2009 01:20 PM
twin turbo ? mbriner Engine 7 06-08-2006 07:15 PM
Twin Turbo Toronado Nightrider Hotrodders' Lounge 4 06-03-2006 02:22 AM
66 ss nova twin turbo jarhead74 Hotrodders' Lounge 0 06-16-2005 03:22 PM
