twin turbo wont stay running - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-02-2010, 09:14 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
as far as setting up the carb for blow thru did i miss anything? what else should i do? i thought i got it all
thanks
  #17 (permalink)
Old 05-03-2010, 10:58 PM
Can u take a picture of the carb? I'l take a pic of mine so you can compare.
  #18 (permalink)
Old 05-04-2010, 01:28 PM
i cant figure out how to post pictures to this website but this is the link
http://www.summitracing.com/parts/HLY-0-4777C/
only difference between a brand new carb and mine is that i drilled out my power valve channel restrictors i have solid floats and i have bigger needle and seats
the choke is still there but it is always open i dont use it i plan on milling the horn off but i wanna make sure i have dont all the internal changes i need to
  #19 (permalink)
Old 05-04-2010, 01:49 PM
Banned
try loosening all of the rocker arms 1/8 turn. I have seen rocekr arms set wrong on new engines SO many times. It may not be the cause, but it very well could be and its an easy fix.
Also, fix the turbos as previously noted.
  #20 (permalink)
Old 08-02-2010, 04:42 PM
ok so the break in is done but i cant get the car to idle it wont say running at anything under 2200 rpm i tried bringing the timing down from what i had it set at for the break in but if i bring it below 35 it wont run unless i turn the idle speed screw up to 2200rpm i to the vacuum can off so that i wouldnt get the previous 70 deg btdc
when i was turning the dist to retard the timing the motor revved up and then i turned the idle speed down to keep the engine rpm down but when i did it would start to die
  #21 (permalink)
Old 08-02-2010, 09:36 PM
i want to have my initial timing down at about 17 deg but i cant get below 35 initial without the engine dying
  #22 (permalink)
Old 08-03-2010, 05:43 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Have you verified that the TDC mark on the balancer is @ true TDC?
  #23 (permalink)
Old 08-03-2010, 08:13 AM
no but it was a new balancer so i assumed it was right i will check
  #24 (permalink)
Old 08-03-2010, 12:04 PM
ok i checked the balancer it is spot on
Twin turbo 400 CID MrCoolDale Engine 12 07-15-2007 06:55 PM
Twin Turbo advice needed ChrisMiddleron Engine 1 04-03-2007 08:47 PM
SBC twin turbo - motor size & specs? stratt134 Engine 10 07-26-2006 01:29 PM
pics of my new twin turbo 427 ratfink14 Engine 9 12-25-2003 09:29 AM
twin turbo advice ratfink14 Engine 4 01-04-2003 08:05 AM
