Twin Turbo's on a Carbureted Small Block Chevy.. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-17-2002, 06:08 PM
4 Jaw Chuck's Avatar
Post
No one said it is impossible, actually if you are motivated this can be a fun exercise. We get all kinds of people on this site, from the seasoned veteran to the junior high school student and some times questions that are asked are to feel out how dedicated the person asking is?
Next question, how much money do you have and are ready/willing to spend? If you think you can just cobble this together from junkyard parts.....well........
— Han Solo
  #17 (permalink)
Old 08-18-2002, 11:13 AM
Post
The only money I will probably have to spend is on the piping. And maybe a carb that can handle the blow through. Not sure if the Holley 750 Double Pumper I have can.
But he has the turbo's, he has the machine shop that has any welder, plasma cutter, or whatever I will need.
I will also need different headers too.
  #18 (permalink)
Old 08-18-2002, 01:59 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
Thumbs down
Hey great idea, but how will you ever get that little, light truck to ever hook up. I had a 92 Sonoma with a heavily modified 4.3 and spun the thing all over the place. As for twin turbos and headers, find a pair of short tubes and flip them (i.e. the right on left with the exhaust exit pointing forward, and the same for the other side). My buddy had a twin turbo Mustang and that is how he set it up. Now all you have to do is find the room (good luck)and weld and turbo flanges for whatever turbos you decide and fabricate all the tubing. Keep in mind exhaust exit, this truck will never be street legal, and there will be no room to run it back, it will probably have to exit in front or behind the front wheels. By the way, this will not be a draw thru system, but a blow through. You will have to have a carb set up for this (not cheap either). To be honest, a mild V8 is perfect for that truck. At one point, I was building a VW Karmann Ghia with a 2388 turbo motor. I ended up having $3500 in a single turbo for it (the whole system), all custom made, but not worth the actual $$$. SOLD IT! Well anyway, good luck with your quest, think it through before spending tons of time and $$$. PLAN PLAN PLAN
  #19 (permalink)
Old 10-13-2002, 06:08 PM
Post
I've been wanting to try a setup like you have been discussing and if you want to sell one or both of the turbos talk to me.
Also how well would chevy TPI work with turbos.
I know it would need bigger injectors and a chip burned.
  #20 (permalink)
Old 10-13-2002, 08:06 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
It will work, and it will fit! Well if you take out the inner fenders... I can email some pics of my turbo S-10 if you are interested. I dont have it running yet, but it is getting closer. It is all disassembled for paint now, but I snapped some shots before I dismantled it.
As for hooking up, I am using 18.5x33 Mickeys and CE 4-link with a 10 point cage to stablize things. I think it just might work.
Chris
  #21 (permalink)
Old 10-14-2002, 04:19 AM
deuce_454's Avatar
Post
forget banks and other companies, check these links out, you are not on uncharted teritory here, the one link even has a calculator that allows you to optimize the boost pressure to fit the turbo cmpressor map. and keep you out of trouble
http://www.geocities.com/windsor_302/TurboPartslist.html
the only thing is that the T04s might be to large
if you plan to run both of them, you have to run arround 20-22 lbs of boost bfore you hav eto upgrade from a T3 to a T04, and by then you are makeing well above 800 horespower, noy wou have to spend serious cash to keep the bottomend of the motor, the tranny and so on from just exploding at that kind of powerlevel
now if you were to ron the T04 in a single turbo config you cauld run 6 to 10 pounds of boost, have quick spoolup and still be makeing arround the 500 Hp mark. honestly i would go with the single turbo and keep the other for replacement...
[ October 14, 2002: Message edited by: deuce_454 ]</p>
  #22 (permalink)
Old 10-14-2002, 07:23 AM
TurboS10's Avatar
Wiki Edits: 2
Post
[quote]Originally posted by deuce_454:
<strong>forget banks and other companies, check these links out, you are not on uncharted teritory here, the one link even has a calculator that allows you to optimize the boost pressure to fit the turbo cmpressor map. and keep you out of trouble
<a href="http://www.sn95.com/projects/turbo/part1.htm" target="_blank">http://www.sn95.com/projects/turbo/part1.htm</a>
<a href="http://www.geocities.com/windsor_302/TurboPartslist.html" target="_blank">http://www.geocities.com/windsor_302/TurboPartslist.html</a>
[ October 14, 2002: Message edited by: deuce_454 ]</strong><hr></blockquote>
You are a little off the mark hear. The T3's will not make anywhere close to 800 HP no matter how much boost. The largest will only flow 35 lbs of air each and that is pushing efficiency hard. Those being the super 60 compressor from the GN. Good luck finding a pair, they are scarce. Also, there are few T04's that will make 500HP from garrett. Most of them are a bit less, so pick wisely if you use a single T04. If you check out ray hall turbocharging at turbofast.com they have calculators to help size the turbo. They also have new T04's for sale, and you can see which one you might want to look for used. However, many of the T04's they sell are not available oe, they are built up units from the aftermarket.
Chris
  #23 (permalink)
Old 10-14-2002, 02:39 PM
drgnwgn289's Avatar
Post
Just tell ya what I know, the fastest vehicle I have ever had the opportunity to ride it was a twin turbo (t-4s) sbc. However it was TPI with alcohol injection and nitrous....
  #24 (permalink)
Old 10-14-2002, 07:59 PM
roys63's Avatar
Post
You can find a twin setup for SBC right here in the Parts For Sale Ads
  #25 (permalink)
Old 12-21-2014, 11:59 AM
SBC and a Turbo
Why are you blowing into the carburetor?? You are loosing pressure for one and 2 fuel is escaping around every shaft through the body of it. You should be pulling through the carb. I will post some photos later but I do this and am getting 780 hp from a 383.
  #26 (permalink)
Old 12-21-2014, 12:27 PM
I've seen this sort of thinking-process a few times. Someone gets x-y-z for free or cheap (in this case, a couple of turbos) and wants to use them. The problem is the cost of installing and making it all work properly far exceeds the available budget or plan.
This would be fine if the turbos were 80-90% of the cost of converting to a turbo set up but they aren't. Besides plumbing (which can become pricey, especially for twins) you have to account for the rest such as wastegates (if they weren't included), BOV(s), boost controller of some sort, serious ability to tune and keep your A/F in proper range (controller), cooling will also be needed as an NA cooling setup will not be efficient enough to a TT setup, the list goes on.
Realize that the turbos on a TT setup (engine, plumbing, electronics, etc) is not the most expensive part of the build. Usually, if a person has enough $ to properly cover the build costs then the turbos is just a fraction of that build.
Personally I'd advise to make sure you have all your bases covered money-wise before starting anything like this. IOW - take the entire cost of all the supporting parts and design needed and put it against the value of two turbos. You may find it is not worth it. I say that because I've seen many a guy start out with grand ideas then discover the true cost to bringing it all to fruition.
Doing something like this for fun or a project is great but only if you are well aware of what you are in for before jumping in. As many here have said - this isn't a simple process (NA to turbo or TT).
Good luck!
  #27 (permalink)
Old 12-21-2014, 06:15 PM
Proud LOSER
Ummmm....
Hots10 - your wrong, take 3 min, Google "blow through Carb for turbo SBC".... when your done get back to us
Byronski and Hots10.... im willing to bet in the 13years since this thread started the OP sold the truck for scrap and is now driving a Toyota....
  #28 (permalink)
Old 12-21-2014, 06:22 PM
Geesh.
Man, I hate it when I miss that this thread is so frickin old.
I just usually just click the "new posts" when I come here and did not notice the date other than it was last posted the same day. Yer right, pointless discussion now.
  #29 (permalink)
Old 12-21-2014, 06:26 PM
Proud LOSER
Originally Posted by Byronski View Post
Geesh.
Wasn't your fault lol, he revived it from the dead....i used to do that all the time....all good.
Dave
