twin V8 engin hotrod - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2002, 04:20 PM
Post twin V8 engin hotrod
late 1960s or mid 1970s Barris or another kustom car builder built a show going hot rod with two V8 engines side by side.
I am interested in building such a hot rod , dose any one know of such a vehicle , Any leads would be appreciated.
Old 11-19-2002, 05:24 PM
Talking
I would find a way to contact the "Tractor Pull" guys. They tandem engines in their tractors.
Old 11-19-2002, 05:27 PM
roys63's Avatar
Post
I think that Tommy Ivo did this with a side x side 4x4 dragster?
Old 11-19-2002, 05:38 PM
roys63's Avatar
Post
Try www.scsgearbox.com/pulling.htm I Thought i still had this.
Old 11-19-2002, 05:44 PM
bullheimer's Avatar
NEVER use credit cards!
Post
man, that is some wild sheeeot!!! but what the hell are they saying when they state a blower is consuming 1000H.P.? dont they mean create? yet they say it twice? any speculation from big giant brains appreciated> feel free to email me an answer so i dont have to check every post i make. ta ta
Old 11-19-2002, 06:06 PM
Post
Uh no, in that case ... The blower is taking 800-1000 horsepower to run 35-40 psi into a motor, problly making 5-6000 horsepower, think top fuel!
Old 11-19-2002, 09:15 PM
Andrew7dg's Avatar
Post
Just to say that you can look at the hurst harry oldsmobile with the two 455 big blocks supercharged. There were running off of a toronado trans. Neat car to think about.
Old 11-19-2002, 10:36 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
That was Ed Roth's Mysterion and I am in the process of building a reproduction as we speak! It had a custom fiberglass body, bubble top, twin Ford FE engines, Cruise-O-Matic transmissions, and '48 Ford rear ends and a ridiculous coil spring suicide front end. I have all the mechanical parts rounded up and will begin throwing plaster this winter for the body and cyclopse nose piece.
[ November 20, 2002: Message edited by: willys36@aol.com ]</p>
Old 11-20-2002, 06:44 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Tractor pullers use an oil drive of some sort. Not exactly sure how it works, but it only allows the engine to add power to the drive train. In the older tractors some motors were tied directly together. Did not work very well, because they would fight each other and if one started missing or something the other motor had to carry the bad one. I have heard these drives they use are very expensive. Just something to concider...
Chris
Old 11-20-2002, 02:11 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
I think putting two V8s inline would be neat. You know, give it the appearance of being one motor.
Old 11-20-2002, 02:56 PM
Wiki Edits: 21
Post
Ah, memories of the great old front engined, twin engined Top Gas rails of the 60s. Two Chevys, two hemis, two FEs, a hemi and a Chevy, every combo you could think of. Those were the days when there was still some creativity in drag racing.
