Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Two of the 4 body lines on door not lining up
  #26 (permalink)
Old 08-04-2012, 05:33 PM
Lizer Lizer is offline
Ok, let me get this straight, you hung the quarter splicing it leaving the upper "belt moulding" area alone. At that time you had a door with a new skin on it, and it fit and matched the lines. You put the new quarter on without messing with the door. At THAT time did the top of the door line up? It would have to being the upper section of the quarter wasn't changed and the door wasn't moved. Am I right, at that point with the first door skin and the new quarter installed the top of the door fit, matching the height of the quarter?
Yes, the top of the door still lined up. The lines on the door were lower than the lines on the skin though. Even now the top of the door will still line up to the top of the quarter, but then the door C stripe lines will be lower than the quarter lines. Which is why the gap between the door and rocker is so large, because the door is lifted up higher than it should be so the door C stripe lines match up with those on the quarter.
