Two cooling questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2006, 04:50 PM
Z-Money Pit's Avatar
I have two quick cooling related questions.
1) Does it matter which way a thermostat is installed on a small block Ford engine? Does the pointed end need to face into the engine block or towards the radiator hose?
2) I just hooked up my new aluminum radiator but it did not come with a cap. What pressure (in lbs.) for the cap is standard for a slightly warmed over Ford 302?
Thanks for your help.
Old 01-13-2006, 05:11 PM
The heavy end of the thermostat goes toward the engine. This part needs to heat up before the thermostat will open.
The radiator should be rated for the cap pressure. I would use a 15-16# cap on a new modern radiator.
Old 01-13-2006, 08:51 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Onovakind67 Is correct, The "Tower End" or spring side needs to be pointed up to be correct...The other way is not just a job...It's an adventure...
As far as the cap goes beg, borrow or steal , (or as a last resort, rent one from auto~zombie) a pressure cap tester. Bring the system up to temp with it plugged in to the radiator cap housing on the radiator..whatever it reads on the gauge, get one in that range (15 to 22 lbs) for say 16 Lbs..you should be good.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Two questions about a BBC RObs71Nova Engine 10 07-03-2012 03:55 PM
Need some cooling suggestions f355bird Engine 14 04-04-2006 06:04 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 03:01 PM
Nuts, Bolts and stripping questions Bluepen Body - Exterior 5 08-14-2003 06:15 PM
cooling questions dk01_99 Engine 11 03-12-2003 02:31 PM
