two cyclinders firing - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2006, 09:20 AM
1992 ford f150 5.0 #4 & #8 not firing. what could be problem?
Old 10-12-2006, 10:33 AM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
two cylinders not fireing
There is not enough info. What have you checked? How is the compression? Is there spark at these cylinders? russ
Old 10-12-2006, 07:17 PM
cyclinders are about 120 each. spark to both. tested injs. seem to be working. new plugs, rotor dist. cap ;and wires.
Old 10-12-2006, 07:59 PM
russlaferrera
Wiki Edits: 2
two cyl not firing
Gave it some thought. The compression is fine. Good spark.
A guess would be an injector. I would try switching an injector with a known good firing cylinder. It's the one part you can't check without looking to see if it is clogged. russ
Distributor Installation & Firing Order leejoy Engine 9 01-05-2006 03:18 AM
firing order FordTrouble Engine 8 11-27-2004 11:22 PM
Firing Order Question airman_turtle Engine 1 10-15-2004 02:54 PM
Carburating a 5.0 HO. Firing order question FalconDaman Engine 7 12-07-2003 03:00 PM
84 305 firing order, please help nitro junkie Engine 7 01-08-2003 12:38 PM
