Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Two cylinders w/o fuel
Old 03-16-2004, 05:21 PM
Jim69Mustang Jim69Mustang is offline
Red face Two cylinders w/o fuel
My 68 Falcon (200 ci engine) worked fine one day. The next morning it started once and then would not fire. Checked ignition circuit, fuel pump, carb and all are fine. Changed plugs. After churning starter until the battery was dead, by chance removed plugs and found four with lots of gas as expected and two completely dry. Those two were closest to fire wall. Why? Stuck valves?
My fleet is running thin. Truck down with bad rear end. Any ideas would be appreciated.
