Two or Four Barrel on a Chevy 265 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2013, 10:14 PM
I have a 1956 Chevy 265 engine that I am about to replace the intake and carb on. I believe the engine originally had a two barrel carb on it. It is currently running a four barrel that is too big; an 800 cfm.
Can I run a Quadrajet four barrel on this, say a 640 cfm, or should I go with a two barrel?
I don't have a two barrel carb and intake so I am not wanting to spend any more money than I have to. I am real sure this engine came out of a 1956 Chevy car. I have pictures of the engine being put in the car dated Oct. 1956.
I have a friend how says they had a 283 in 1956 and this engine is not a 265. Not really believe this.
Also, the four barrel and intake that I have is from a mid to late 60's 350 engine. Will this intake fit on a 265? I don't know how many small block parts will interchange. The newer intake has a place for a choke thermostat that I believe will help with starting and running.
Some advice and help with this project would be greatly appreciated.
Thanks.
Old 04-28-2013, 10:24 PM
Banned
283 would be '57 on
Old 04-28-2013, 11:39 PM
vinniekq2's Avatar
carter wcfb/carter 550/any 600 or smaller carb will work just fine.
If the 800 is a thermoquad,it will work fine.
what gearhead said,283 was introduced in the 57 model cars.The 265s are getting quite rare
Old 04-29-2013, 01:58 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
The 265 also came with a power pack head package, the HP setup for it's day for Chevy.
Semper Fi
Old 04-29-2013, 10:47 AM
All 1955 (265), 1957 - 1968 (283), 1962 - 1968 (327) 2-barrel and 4-barrel intake manifolds will interchange regardless of engine size. The 1955-1968 2-barrel and 4-barrel intake manifolds can be identified by the oil fill tube next to the thermostat housing. The 1969-up manifolds do not have a oil fill tube on the intake manifold.
Carburetors for those manifolds will be a Rocherster 2GC 2-barrel, a Carter WCFB 4-barrel or a Rochester 4GC 4-barrel. Those 4-barrel carburetors are rated at 500 CFM .
Old 04-29-2013, 09:12 PM
sedanbob's Avatar
I had a '55 chevy with a 283 (didn't come that way - was transplanted - began life as a 6). It had a WCFB 4 barrel - ran good.
Old 04-30-2013, 05:03 AM
cal1320's Avatar
[QUOTE=John316;1671049]
QUOTE]
Yes, you can use a Q jet on the 265. The CFM of the carb will be around 750, but that is a maximum CFM. The beauty of the Q jet design is it will only supply the airflow needed for that particular engine. The small primarys deliver great throttle response and great mileage too. It will fit on a late 60's intake.
If it's a 265, there will be no side engine mount provisions on the block.
Old 04-30-2013, 01:37 PM
junior stocker's Avatar
The 55 and 56, 2 and single 4 barrel heads had ports that are extremely small; using ANY later intake manifold will result in an extreme mismatch between the intake manifold ports and the intake ports of the heads. The early 56 dual quad setup also used these heads with small ports. Mid year or so in 56, they switched to larger port dual quad intakes and larger port heads. You MUST use the 55-56 2 and single 4 barrel intake manifold gaskets with a latter intake or there may be a leak. Later intakes will work, but there will be an offset in performance due to the port mismatch; is it even worth it? I have two of the early 56 dual quad setups, and a single 4 barrel intake/carb (WCFB) to go with my #5603 casting number heads. I supposed you could use an adapter and a Quadrajet with a stock, single 4 barrel intake, or use an original WCFB ($$$), or even a Rochester 4 Jet. An adapter with a Holley is another option. Basically, you're very limited due to the small port heads you most likely have. Butch/junior stocker.
265 chevy marl1216 Engine 5 11-30-2010 09:57 AM
Chevy 265 V8 VandenBos Engine 1 06-02-2010 04:08 PM
HOW MUCH H.P.'s DID THE CHEVY 265 HAVE STATUTORY GRAPE Hotrodding Basics 11 06-24-2007 10:57 PM
265 chevy 1939 dan Hotrodding Basics 2 06-03-2004 04:14 PM
Can I replace two barrel carb with four barrel on chevy 305 maverick19642001 Engine 6 02-20-2004 11:00 AM
