Two kinds of Holley 94's? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2005, 02:35 PM
rlackey's Avatar
Rich Lackey
Last journal entry: Rich Lackey is back on Hotrodders!
Hi all, my intake and carbs were safely smuggled into the UK thanks to my mom, and will be smuggled into SA in July. My brother took some more detailed pictures for me than I got from the guy who sold it to me.
It seems I have two kinds of 94's on here judging from the tops of the carbs. Can anyone shed light on this for me?
Thanks!
Rich
Old 05-14-2005, 05:43 PM
lluciano77's Avatar
They look the same to me. The only thing I canm tell that is different is the fuel fittings. Those are interchangeable.
Are the part numbers the same on each carb?
Old 05-15-2005, 01:11 AM
rlackey's Avatar
Rich Lackey
I am not sure about the part numbers because I can't get at them myself yet, but I'll ask my brother to check. If you look at the very top rim of the carbs you will be a difference between the bank closest to the camera and the bank behind them. I'm not that worried, as you say they all are definitely 94's but I wanted to check just to make sure. My brother mentioned that three are slightly taller than the other three but it seems that when the air cleaners are installed everything lines up right.
I just thought it a bit strange that's all. I suppose it's wishful thinking to expect six totally identical carbs on a 6x2 setup. I was seeing the same thing looking at Stromberg 97 setups, some would be small logo 97's others large logo 97's on the same intake.
Doesn't matter I guess.
Thanks!
Rich
Old 05-15-2005, 09:32 AM
Maybe the carb manufacturer had different tops for different air assembly fastening systems.Flow should be the same.Magnificent set up.
Old 05-15-2005, 09:55 AM
lluciano77's Avatar
I see what you are saying. The throttle openings are different. As long as they flow the same and are calibrated the same it should be fine. The way you can tell is to see what factory restrictions they came with. For instance Holleys have jets and ide feed restrictions. See if they are the same in each carb.
You could also measure some of the restrications in each type of carb. By eye may even be accurate enough for this.
Old 05-15-2005, 01:17 PM
rlackey's Avatar
Rich Lackey
Thanks guys!
Rich
Old 05-15-2005, 02:41 PM
By the way,have you ever been to the Kyalami track?
Old 05-16-2005, 01:39 AM
rlackey's Avatar
Rich Lackey
Nope, not yet but I would like to!
Rich
Old 05-16-2005, 12:04 PM
Biggarmike's Avatar
Chief Procrastinator
The ones in the "top" row are from earlier applications where the air cleaner attaches with a metal band type clamp. The others are newer the aircleaner fits onto the flange and is attached by the center bolt.
That lousy Holley carb cool rockin daddy Engine 30 02-29-2008 02:01 PM
Carb comparison Demon vs Holley DTL504 Engine 12 12-29-2004 02:53 PM
Fenton 3 carb and Holley 94's? Rat255 Engine 1 12-15-2004 10:10 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
holley 94's himmelberg Engine 0 03-03-2002 07:35 AM
