Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Two paint questions...
Old 04-15-2011, 07:41 PM
V8&4spd V8&4spd is offline
Last journal entry: Paint
You can use razor blades to remove the lacquer paint. It has to come off of there if you use urethane paint. The factory primer can stay, that is some tuff stuff. Urethane paint can cause what is called a lacquer reaction. It can cause the lacquer under the urethane to wrinkle up.
