two pitted pistons 383 vortec chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2012, 10:59 AM
My stroker had a screw go into one of the cylinders. Caused a water leak. I pulled the head and find a lot of piting on one of the pistons and a few dents on the other piston next to it. This is a relativly new motor 20,000 miles on it. I got it directly from gm performance parts. I am going to have the head checked for cracks. Both the pistons #4 & #6 showed water incursion. What should I do about the pistons if anything. Also what should I look for to rule out any other damage that might need fixing?
Old 08-05-2012, 12:18 PM
vinniekq2's Avatar
strip the engine right down,inspect everything, basic refresh time.May as well check balance while its apart.
Pistons for a Vortec engine John_H Engine 8 08-25-2009 10:20 PM
Can the newer Vortec pistons and rods be used in an older block? Twistedwrench Engine 4 02-13-2008 08:38 PM
Cam selection for Vortec Chevy 383 mytruckownsit Engine 7 06-14-2006 08:16 AM
Chevy 383 What cam to run???? Also Forged or hyper pistons?? 89SDime Engine 19 02-28-2006 12:59 AM
vortec heads and dome pistons blazin47 Engine 14 10-03-2005 08:56 PM
