two sectioned tail shaft why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2004, 02:10 PM
slavegear's Avatar
New Member
Question two sectioned tail shaft why?
could i have an answer on this one people,why do some vehicles has a two piece tail shaft.as i was cruising the wreckering yards for research i found many have two section, why? thanks.
Old 01-08-2004, 03:09 PM
STUPID is as STUPID does...
Because of the length... when the shafts get to long you have a number of issues to deal with. Harmonics, twisting, and weight.
Long tail shafts require thicker materials to return the same strength (both torsionally and longitudinally) which adds weight to the rotating mass. This can cause vibrations and actually eats up power to turn the shaft. Splitting the shaft allows using a thinner, lighter material and smaller u-joints. This reduces rotating mass and actually makes for a less vibration prone installation.
Mark
Old 01-08-2004, 03:56 PM
willys36@aol.com's Avatar
Wiki Edits: 21
http://hotrodders.com/showthread.php...ive+shaft+long
