Two tone masking questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2010, 09:31 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
I will be spraying the body of my car soon. It will be two tone just like my avatar. Just from doing my homework, my understanding is it's best to paint from top to bottom to avoid bumping your paint. Makes sense. What about when you're painting two tone and the darker color is on top? I plan to spray the orange first a little ways past the division line. The spec sheet says to let the paint cure for 8 hours before taping / masking. Mask, then spray the black.
Would this be the best way, or should I do the black first and then orange? Doing black first seems like it'll pose masking issues (ie black showing through orange).
Old 10-05-2010, 10:26 AM
302 Z28's Avatar
I'm kinda unclear about where you would have black showing through the orange. Aren't you going to have a sharp division between black and orange?
Vince
Old 10-05-2010, 10:37 AM
Correct. There will be a sharp division between the two colors. I guess what I'm asking is, what is the best way to do so? I was thinking I would spray the orange first slightly up past my mask line. Attached are some examples I put together.
Then, mask off the car for black and shoot. Does this seem right?
ID:	48636   Click image for larger version
Old 10-05-2010, 10:51 AM
What I was trying to say earlier is if I did the black first using the above method, there would be color difference in the orange where the black overlapped, correct? I hope I'm explaining this correct.
Old 10-05-2010, 10:55 AM
302 Z28's Avatar
Your not going to have chrome strip or pin striping along the division line?
Vince
Old 10-05-2010, 11:00 AM
302 Z28's Avatar
Use 3M's Fineline masking tape and place it right on the edge of the black and lay on the orange so that the two colors do not overlap, but they butt up flush with each other.
Vince
Old 10-05-2010, 11:03 AM
are you using single stage or base/clear??
Old 10-05-2010, 11:05 AM
Vince
There are a couple of options. I could use the trim line to cover where the two tone meets, or I could use the body crease. I'm thinking that using the trim line would better to hide the slit in color.
This image shows a good example of how some people make use of the body lines for the two tone.
Old 10-05-2010, 11:06 AM
Vince
Makes sense. I have some 3M fine line masking tape. I'll give that a try.
Old 10-05-2010, 11:09 AM
Well, actually both. I'm painting with single stage followed by clear.
2 coats s/s
2 coats clear
cut orange peel with 400 - 600
1 flow coat of clear
Old 10-05-2010, 11:13 AM
i would spray the orange then fine line your cut off point mask it and spray black .. this becauser the black will cover with the least amount of coats and reduce the hard line. apply multiple coats of clear to allow wet sand the line smooth and re-clear with 2 coats resulting with a smooth transition between colors
Old 10-05-2010, 12:31 PM
cyclopsblown34's Avatar
Colorsanding painter
Since it is solid colors, nib off with somewhere around 400 grit the color change line before clear coating, it will sereiously lessen the presence of the change when the finish is touched. The other option is masking it and let the other color show basically an orange pinstripe in the black and black pinstripe in the orange and then nib the edges with 320. believe me, it is the best way to avoid feeling the color change in the finished product. It'll use way less clearcoat to cover the line.
Old 10-11-2010, 06:05 PM
I've done a number of two tone paint jobs and I have always done it the way you have mentioned before. Spray the orange a little past where you want the line then mask it off and spray then black. What kind of base coat system will you be using? The waiting 8 hours seems pretty steep for masking time. If you are worried about disturbing the pearl in the base coat with a tape line then spray an inter coat clear over the orange before you mask it off. It just insures you that the orange will not be disturbed.
Old 10-13-2010, 01:42 PM
Thanks for all the tips, guys.
Old 10-17-2010, 07:40 PM
outlaw17's Avatar
Also depends on the booth, If your using a downdraft I'd do the top first , if its a cross draft I would do the bottom first.
***** GO OILERS GO *****
1940 Ford pickup box and door questions? Skiman Hotrodding Basics 10 04-04-2011 05:50 PM
Some B&M 250 questions, JimDavis maybe? kick_the_reverb Engine 6 05-15-2006 10:26 AM
ANSWERS TO COMMON QUESTIONS -- PLEASE READ BEFORE POSTING Jon Hotrodders Site Suggestions and Help 0 07-07-2005 03:58 PM
Masking Door Jams etc. 36ford3window Body - Exterior 9 02-06-2005 08:17 AM
