two ways to lower the back of a 2wd ranger p-up - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2011, 06:37 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
today we lowered the rear of my sons 1997 2wd ranger p-up some more
we had all ready lowered the rear about 2.5" by doing a spring shackle reversal/flip (pointing up) earlier this year
today we put a 8.8 out of an explorer in it, because the spring perches are on the other side of the axle, when compared to the stock 7.5
so now the axle is on top of the springs, instead of under the springs, lowering the truck about 5-6" (we haven't measured it yet)
we had to put the spring shackles back to stock (pointing down)
we also had to redrill the spring perches to move the rearend back about 1" for the driveline length
the other advantages are that its a way stronger rear (31 spline) ,posi diff, and he is going from 3.45 gears to 3.73 which will help with the lost power due to bigger tires and wheels
here is a before and kinda after pic of the truck
and before and after of the rears and susp.
redrilled perches
ID:	59704   Click image for larger version
Name:	ranger (800x451).jpg
ID:	59705   Click image for larger version
Name:	ranger2 (800x451).jpg
ID:	59706   Click image for larger version
ID:	59707   Click image for larger version
Ford Ranger seat back adjuster matt167 Interior 0 06-13-2010 10:46 AM
Lower compession = lower octane? Arrowhead Engine 8 11-18-2007 05:45 AM
How much lower will the frame lower once the real motor is installed ? Tonythefish Suspension - Brakes - Steering 3 02-05-2007 04:14 PM
4 ways to do things... OneMoreTime Hotrodders' Lounge 1 09-08-2006 11:49 AM
How to fix Lower Valance back to Factory new look? satexasf150 Body - Exterior 1 11-23-2005 01:12 AM
