Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TX smog compliance on OBD2
Old 10-08-2008, 10:51 PM
Soul_Hunter Soul_Hunter is offline
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
the rules may be different for Travis county, but for the Harris county area on 1996 & newer, Texas doesn't use the "sniffer" any more.
it used to be if the inspection machine wouldn't communicate with the vehicle, then you would run it on the dyno. now if it doesn't communicate the inspection & test end and you have to repair the vehicle, or if its the fault of the inspection machine, go to another inspection station.
for the emissions part of the test they will do a visual check for emissions components & check the CEL light being on. they also check for codes and a maximum of 2 readiness monitors not complete.
if its a 2001 or newer, you can only have 1 readiness monitor not complete.
