type 11 GM power steering pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2003, 09:30 AM
New Member
could anyone tell me what vehicle uses a GM type11 power steering pump as i believe they are much smaller in size. I want to install a pump in my '37 chevy street rod and i am short of space,I can only run 1 "vee" belt due to blower pulley taking up most the available space
Old 07-18-2003, 09:40 AM
I am not sure about the type 11 box but..... The Mullins billet steering box is a very compact nice unit and can even be had with a remote power steering reservoir........
Tony....
Old 07-18-2003, 09:59 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
I went to the local boneyard & here are at least 3 to choose from. (1) late model V6 GM front wheel drive, (like the one in the wifes 92 park ave.) its small, has a remote fill , but its on a billet type bracket.
(2) Geo or Chevy Tracker, similar above BUT its on a steel bracket
(3) ford Probe, they also use a small p/s pump w/remote fill also & its mounted on a steel bracket. which means you should beable to refab it to make it work.....joe
