type f vs dexIII - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2012, 09:31 PM
type f vs dexIII
I am trying to create a poll basically, wich atf to run type f or dexronIII? transmission is a non lock up chrysler A-518 in a 1991 dodge power ram 150.
Old 01-09-2012, 07:34 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Call your local Dodge dealer and ask the service manager.
Old 01-10-2012, 05:39 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Use either oil.
If you think one oil is going to ruin a trans over the other, that is incorrect. Neither of those oils will make a trans shift wonderful and the other oil cause bad shifts.
If you want to mix the oils , that will work too.
If you want to mix some synthetic oil in there, go for it.
Old 01-10-2012, 07:53 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Originally Posted by Crosley
Use either oil.
Things must have changed since the 60's when I first started working on cars then. I was told that Ford and GM used a different composition in their automatic transmission clutch facings and that the wrong oil would degrade the clutch facings, and cause premature failure. In the last few years, I was told that Dexron III was developed to be compatible with the Type F used in Ford. I have no idea why there is a Dexron IV . Of course all this information came from various sources, that I don't recall, so it is to be taken with a grain of salt. I would still call a dealer, rather than take a chance on ruining a transmission. Big Al
Old 01-10-2012, 05:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Things have changed over the decades, that information no longer applies.. The trans oil , the friction materials used in automatics have changed greatly.
Modern friction materials used in aftermarket are compatible with the oils in use. You can mix oils wither dyno oil or syn oils.
The old days there was whale involved in trans oils. That method was out lawed around 1970 if my memory is working or close to that year.
If the member of the original post is worried about his trans, go purchase the Dodge ATF +4 oil and use it.
Old 01-10-2012, 08:55 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Thanks for the update Crosley. I remember that we had gotten a new truck at the mine just a couple years ago and it specified Mercon oil. I guess it is a gimmick to get you to spend extra to buy oil from the dealer.
Old 01-10-2012, 09:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
actually no gimmick.
Many trans in recent years use a converter lock up strategy that ''pulses the clutch on = aka PWM'' This slips the clutch for smoother application. These new oils have friction modifers in them so the clutch does not ''chatter'' as it is slipped.
The original post here mentions ''non lock up'' converter... so i suggest use of the fluid he wants.
you can even add engine oil to a automatic trans. A trans with morning sickness in cold weather ( old , hard internal seals) add a quart of 5 - 20 weight engine oil. This bandaid method thickens up the oil enough the trans will often operate till it really dies a bad death. LOL
Old 01-10-2012, 09:48 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I actually did rebuild a few automatic transmissions in years gone by. The last one was in 1990. Almost seems like a lifetime ago. I still have the home-made tools in my roller cabinet. I would love to rebuild another, if the oportunity arises. Trying to keep somewhat busy in this retirement. Just waiting for one of my buddys to drop a trans pan and find a handful of clutch facing. Happy days !
Old 01-11-2012, 05:32 AM
Irelands child's Avatar
I guess I don't understand why anyone would want to deviate from Type F, if that's what it calls for either F or FA seem to be available most anywhere, i.e. NAPA, Walmart, Tractor Supply. The same is true for the Dextron lll.
Irelands child
Old 01-11-2012, 07:37 AM
Type F will give slightly firmer, cleaner shifts in GM trans. I have run it many times in 700R4's & 4L60E's. I don't mix types, though. I will fill and drain a couple times (after cycling thru the gears in the shop) to flush out the old, along with a filter change. It's no miracle cure for a wore out, slipping trans though. No problems doing this...
Old 01-11-2012, 09:56 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
I would love to rebuild another, if the oportunity arises. Trying to keep somewhat busy in this retirement. Happy days !
too bad you are so far away, I could keep you busy
trans. rebuild, etc, etc,etc,
Old 01-11-2012, 08:07 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I do have a 327 rebuild coming up real soon. Found out yesterday.
Old 01-12-2012, 09:12 PM
the reason i am considering dexronIII or type f is because i have talked to many different people about thbis subject, wich trans fluid to use in a non lock up A-518, many people have said to use atf+4, but i am not interested in suing +4 because of all the friction modifyers.... and the guy who re-built my transmission told me not to use a synthetic atf in it. he said dexronIII is what i need to use or a non synthetic universal fluid. my old man ran type f in his 727s over the years with great results and i was hoping type f would be ok to use in my transmission since it is a non lock up. i have had a few people say not to use type f in because it has an overdrive but then some say it is fine to use. i cant ask my old man because he passed away, so thats why im asking you guys, figured somone on here would have enough knowledge to know. i have narrowed it down to dexronIII and type f. i would like to run the type f a little more over the dexron just because its got no friction modifyers in it. but then again the dexronIII is not to heavy in friction modifyers and it has better additives? so i been told anyways i dont know that for sure, i know dexIII is newer technology then type f.
Old 01-12-2012, 09:34 PM
topwrench's Avatar
Last journal entry: fish carb
Oh boy!
Im a Chevy guy but back in the late 60s I worked for a Ford dealer in Miami,back then they would say use of other than Ford approved fluid would void the warranty,I bought a 69 ford p/u n ran the dog crap out of it on Dextron sold the truck in late 70s with 150gs on the odometer,transmission never missed a lick,I towed car trailers to racetracks with that truck every weekend,towed a 28 foot boat back n forth to the keys,but I changed trans fluid bout twice a year or so,this to me is the most important thing.
If you look at a gallon of O'Reilleys fluid (cheap stuff) it is approved for type f n dextron as well.
The oil in auto trans runs very hot n after a given number of miles will start breaking down,also filters get clogged n restrict flow,making the fluid run even hotter.So while I'm not disputing anything that was said here or advising you to pour Dextron or Mercon fluid in there I gotta tell u.
Change fluid often n your trans will live a lot longer!
Old 01-12-2012, 10:23 PM
so when you say oriellys atf are you refering to the orielly global atf? i have looked at that before and i couldnt tell if it was a synthetic or not? i ran the napa house bran dex/mercIII atf in my 727 that was in my 76 four wheel drive truck and never had any issues with it at all. i dropped the pan and changed the filter and filled it back up with dex/mercIII once a year never had an issue with that transmission. The non lock up A-518 i have now is frshly re-built, i'm hoping i dont ever have to mess with this transmission again other then changing filter and fluid. My old man ran type f in his 727s but the 727 in his 70 plymouth cuda had alot of modifycations to it, shift kit, added clutch plates higher line pressure better pump and converter it was bolted behind a 440- 6 pak and that 727 of his was the best shifting auto i have ever driven that thing would tear your head off when it shifted had amazing throttle response and he always told me that type f is the best fluid to run in a torque flight, the A-518 is very simliar to the 727 only differences are the 518 has an overdrive unit attatched to the back and slighly different valve body set up. But if type f works well in the 727 it shouldnt work any different in the non lock A-518 then it does in the 727, correct? i mean if there is any reason type f wouldnt perform the same in a non lock up A-518 as it does in the 727 someone please explain, cause i dont see any reason why it would be any different?
No type F ATF, what can I use? Augusto Transmission - Rearend 16 10-02-2011 01:48 PM
What type to use Martygraw Body - Exterior 1 02-08-2010 12:52 AM
GM type 2 or type 3 power steering? dlc1979 Suspension - Brakes - Steering 0 09-22-2008 07:48 PM
Type of car 1935 Ford Steve Introduce Yourself 1 03-23-2006 12:50 PM
