Type "F" VS Dextron - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2006, 07:16 AM
Last journal entry: Latest picture
Type "F" VS Dextron
I'm in the process of rebuilding my Dodge 518 transmission and was told that I should use type F fluid in it instead of the recommended Dextron by the local parts guy. What's the difference? I always thought that type F had friction modifiers in it, and were only for Ford trannies. Any advantage to using it in Dodge or GM trannies? Thanks./ Dan
www.geocities.com/dantechfab
Old 08-08-2006, 02:45 PM
type F has less friction modifiers in it. It will cause a harder shift and less slipping...just like the "trick shift" type stuff.
Old 08-09-2006, 10:08 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I would suggest your using the modern fluid type that the kit manufacturer recommends. They are the ones that made the clutch and band material, so they should know..... right?
Of course, I like Mobil 1 Synthetic.
Old 08-11-2006, 06:53 AM
tnsmith10's Avatar
when will it rain???
read the dipstick, itll say what fluid to use.( most applications)
Help picking posi type carrier dpjim2 Transmission - Rearend 10 02-05-2006 02:54 PM
What type of clips do you use for holding door panels on? hemi43 Interior 4 01-05-2006 10:23 PM
Automatic Transmission Fluid Type A jimra1944 Transmission - Rearend 2 11-21-2005 02:31 AM
Type FA transmission fluid 406chevelle Transmission - Rearend 6 03-15-2005 08:03 PM
Type F in a TH350 65 streeter Transmission - Rearend 3 06-24-2004 12:59 AM
