type of gasket sealer to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2010, 09:04 PM
stoney 81ta's Avatar
what type of gasket sealer to use when installing a thermosat housing,does color matter all i have is the red high heat sealer.
Old 07-24-2010, 09:49 PM
Greg T's Avatar
www.krusinklassics.net
I just use the spray "High Tack" stuff from Permatex.
Old 07-24-2010, 10:10 PM
hemi joe's Avatar
loves ex cop cars
if you have gm motor use the fel-pro #35562T,you don't need sealer with this gasket.
Old 07-24-2010, 10:58 PM
sqzbox's Avatar
My pipes are my music
If you use the fel-pro gasket and no sealer and it still leaks, you got a bad thermostat housing.
Old 07-25-2010, 12:03 AM
I use black RTV sealer from permatex. Seems to work better than the red or the blue that I used in the past. Although I took apart an engine that had been put together with brush on copper sealer.. that stuff was REALLY sealed up good. Better than any silicon stuff ive ever used.
Old 07-25-2010, 05:36 AM
sqzbox's Avatar
It only takes one gorilla with a 1/2 ratchet one time to warp a thermostat housing. Another way to destroy one is cut the ridge on the flange with a sharp gasket removing tool or a putty knife. It's only aluminum. Torque to specs and no farther. On used housings, I check it with a straight edge and inspect the ridge. If either check fails, I toss them. Why? because I know I'm setting myself up for failure. RTV is just a band aid for a boo boo. It will work in some cases, but why not do it right the first time.
Old 07-25-2010, 06:31 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
It it's not an "O" ringed housing it's easy to flat sand and make it useable.
Semper Fi
Old 07-25-2010, 09:26 AM
sqzbox's Avatar
Flat sand and loose the ridge that seals the gasket. RTV will seal it, but who want's RTV goo sticking out between the housing and the intake. I guess if it doesn't bother you go ahead and use it.
Old 07-25-2010, 06:56 PM
Thanks for all your input,i ended up using the permatex copper with a stock paper gasket looks good so far.
Head gasket compatibility Greg T Engine 28 05-06-2010 11:50 AM
big block mopar oil pump gasket??? randyhemi Engine 6 11-09-2008 08:11 PM
Carb gasket dual plane intake to 4 BBL D. Newland Engine 3 09-26-2008 04:36 PM
gasket or sealer? akm Hotrodders' Lounge 20 12-18-2005 06:22 PM
Gasket sealer atlantis Engine 4 02-27-2005 08:41 PM
