type II power steering pump/reservoir - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2013, 01:31 AM
Having a hell of a time with type II power steering pump, can anyone help me with picture or explain the proper line coming to and from the power steering pump to power steering box and remote reservoir. One side of the remote reservoir is open and flows freely, other side has a taller nut with a hole in the side of it. Which line goes to the back of the pump? I tried the larger hose and after bleeding the air out of the system pump still howling. Then switched large hose from back of pump to tall nut side of the reservoir and bled air again and this time made enough foam for my coffee. Also made the front line from the pump to the box chatter like hell like way to much pressure. Something is a miss here??? Please help 327 sbc march performance style track serpentine set up.
Old 05-20-2013, 07:50 AM
S10xGN's Avatar
Gotta love a turbo!
The HP line from the pump goes to the box inlet, the box outlet should go into the res fitting, then from the open res port and back into the pump suction.
Looking for help on a Type II Power Steering Pump problem Pyratess Suspension - Brakes - Steering 3 04-29-2012 09:00 AM
power steering, sprays fluid out the vent whole on reservoir cap colt45 General Rodding Tech 2 06-02-2011 06:38 AM
re: type two power steering pump camaro dave Introduce Yourself 1 11-08-2004 09:59 AM
Remote reservoir power steering V8 S-10 Suspension - Brakes - Steering 1 09-17-2003 05:51 PM
type 11 GM power steering pump 37 chevy Suspension - Brakes - Steering 2 07-18-2003 08:59 AM
