Type of libricant for a distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2003, 11:34 AM
I have a 1972 Olds 307 V8 with a single point distributor and I want to refresh the lubrication on the internal working parts of the distributor. What type of grease is most preferred?
Old 09-18-2003, 11:48 AM
SAE Member; ASE Master Cert
Auto parts stores can supply small tubes of lubricant that is designed for the rubbing block/cam on points-type distributors. The lube can also be used, very sparingly, on the weights/advance mechanism. Use very minimal amounts of lube, as you don't want the stuff to be slung around inside the cap.
