Type pf Glue? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 09:59 PM
Type pf Glue?
I have a set of M/T aluminum rocker covers and where the PVC goes into the grommet, the grommet has split into two pieces (the part that goes into the rocker cover and the part that fits outside of the cover). Have been unable to locate a similar grommet (about 1" thick by 1 1/2" diameter that has a 5/8" hole in it) and because of that have to rely on gluing it back together; unless someone can tell me where I can get a replacement. I tried contact cement and it doesn't hold (because of the heat, I suppose). Any suggestions as to what type of glue can be used here? The grommets that are used on Chevy rocker covers are too small as the aluminum covers are about 1/4" thick.
Old 04-22-2013, 12:36 AM
Faith - Respect - Trust
Have you tried JB weld...used it on the exhaust of one of my cars a bout 3 years ago...still there, holding like a champ.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
27Tall T (04-22-2013)
Old 04-22-2013, 04:34 AM
Banned
3m black weatherstrip adhesive
found at any parts store..
the sheet metal in the sun gets hot and it holds..
just make sure there is no oil when you "glue"
The Following User Says Thank You to gearheadslife For This Useful Post:
Old 04-22-2013, 10:35 AM
malc's Avatar
Living At The Speed Of Life
Grommets galore @ Summit.
The Following User Says Thank You to malc For This Useful Post:
Old 04-22-2013, 10:48 AM
kso's Avatar
kso kso is offline
Yep, Summit. No type of glue will hold that grommet together in use.
The Following User Says Thank You to kso For This Useful Post:
Old 04-22-2013, 11:43 AM
life is a temporary assignment
I wouldn't try to fix it... Buy a new one..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
Old 04-22-2013, 02:02 PM
I"Ve tried all types of "rubber" type of glue and they hold for awhile then let go. I guess the hunt is still on for a replacement. Never tried JB weld, only on metal type parts.
Old 04-22-2013, 02:28 PM
I think you will be spinning your wheels trying to glue it... Someone should have a new one,, There was one in it...
Old 04-22-2013, 09:35 PM
Went to my local parts store again and this time browsed through their rack of odds and ends and found the same grommet! It is a Ford replacement for a Ford rocker cover, which I've been told that they have used for a number of years. Go figure.....fitting a M/T rocker cover. Thanks to all the replies.
The Following User Says Thank You to 27Tall T For This Useful Post:
NEW INTERIORS (04-22-2013)
Old 04-22-2013, 09:54 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Yup. 1" valve cover hole size with 3/4" PCV valve hole
Ford Part Number C8AZ-6A892-D
NAPA / Echlin #2-9104
Mr.Gasket #6379
if anyone else runs into this.
The Following User Says Thank You to 66GMC For This Useful Post:
Type 2 vs Type 3 Injector 64nailhead Engine 4 12-19-2012 05:03 PM
So How Much Glue ? Coodeville Interior 4 03-12-2011 11:50 AM
New Type of Glue DanTwoLakes Interior 6 01-12-2011 04:05 PM
GM type 2 or type 3 power steering? dlc1979 Suspension - Brakes - Steering 0 09-22-2008 07:48 PM
Glue GMCTRUCKS Off-Topic 5 01-04-2007 03:24 PM
