Which type of sanding board/block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2010, 06:47 PM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Hi all,
Just a quick question about sanding. Has anyone used the durablock sanding blocks? I'm thinking about the 16" block for the large areas of my panel truck. Would a wooden handle type with metal base be better, or a more flexible type?
thanks,
James
Old 01-18-2010, 09:03 PM
302 Z28's Avatar
Buy the complete Durablock package, you will not regret it.
Vince
Old 01-19-2010, 08:03 AM
cboy's Avatar
Last journal entry: Finished
Vince is right on target once again. Basically, buy or make as many different sizes and shapes of block as you possibly can. I bought one of the smaller Durablock "sets" (it had 6 different shapes and sizes) and I not only used every one of them I craved even MORE. It seems like every panel on a car has its own unique shape and no single block will sand all those shapes properly.
Always learning...and sharing what I've learned.
Old 01-19-2010, 08:05 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
The DuraBlocks are good Sanders for the money, but I really like these better-they conform to curves, and you can adjust the amount of "Flex" with the three stainless rods-
http://www.summitracing.com/parts/AFY-8907688337
I don't think there is one "best" Sander. Heck, one of my favorite Sanders is a piece of Oak that I put through my Wood Planer (so it's perfectly flat)-just put some adhesive backed Paper on it and go to work (I like Carborundum). DuraBlock makes one that is round that I use a lot, too. Lots of different ways to skin a Cat-
Old 01-19-2010, 10:06 AM
All of thoes suggestions work great and like 35window said, theres more than one way to skin a cat. I've used everything from a block of wood to the durablocks, and even have used a short piece of hose and wrapped a piece of sandpaper around it.
Old 01-19-2010, 07:00 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Another vote for Durablocks here, I have used some other things, but Durablocks just feel great and work great. Yes get the set.
Old 01-20-2010, 01:32 AM
Hwyhogg's Avatar
Durablock set it is...thanks again; finding this site was the best "mistake" I've made.
Old 01-20-2010, 07:59 AM
durablocks gets my vote, i don't know what i did before i had them!
How to tell paint type? smithkustoms Body - Exterior 21 07-30-2011 10:44 AM
What type of clips do you use for holding door panels on? hemi43 Interior 4 01-05-2006 11:23 PM
DA sanding vs hand sanding Kevin45 Body - Exterior 31 07-19-2005 02:37 PM
wet sanding and saving my finger tips.... onebadmerc Body - Exterior 14 12-30-2003 06:41 PM
Sanding, Dry vs Wet, Air vs Elec Bluepen Body - Exterior 3 05-12-2003 04:45 PM
