types of differentials - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2005, 12:53 PM
cesar9's Avatar
Hi guys:
This question has been probably asked before, but i have been hearing people talk about types of differentials, and i am confused. Limited slip, locker, posi track(or something like that), Detroit locker, and what is the one that when the car is in the air, and you turn one tire, the other goes the other way. Can somebody clear out this for me by telling me their differences, uses and other info?
I would really appreciate it. Thanks.
Old 05-03-2005, 01:47 PM
mj_lover's Avatar
expert lurker
Last journal entry: day one!
diff's 101:
open diffrential: most comon, found in almost all cars and trucks. allowes wheels to spin at different speeds, this is also the one where if one wheel is stuck, the other will spin lika mad in the other direction.
limited slip, posi: a happy midle ground between full locked and open. basically this unit always keeps a little power to the stuck wheel, assistin in traction, but not as nice for turning. (when you turn, one the outside wheel travels faster then the inside wheel)
lockers: brands include detriot and arb. this unit keeps full power on both wheel no matter what. used alot in off roading, and drag racing. turning is all but impossible with locked diffs.
if you need more info hit www.howstuffworks.com and do a search.
hope it helped!
1988 Jeep comanche 4.0L
1991 5.0L explorer
Old 05-03-2005, 02:36 PM
Tazz
off the cuff...
sound good to me Dude....are you planning a diff. change over in the future? They come in a lot of different sizes too and I'm not just talking gears here. The housing are big and small and GM and Ford and Chrysler.
Tazz
Rat Rods Rule!
Old 05-03-2005, 04:00 PM
More rust
Wrong on the locker...
It is either fully locked or fully UNlocked. It essentially acts like a spool or an open rear, depending on if you're under throttle or not (the throttle is like the on/off switch for a locker).
Turning is no big deal with a locker... Didn't even notice I had a locker most of the time, occasionally with a slow (like parking), sharp, under throttle turn you'd hear a bang but for the most part it is no big deal.
IMO, and this applies only to 9" Fords, I'd never consider any other differential than the Detroit Locker. Opens just flat suck, I have a pile of them in the basement, just put one in my Mustang to get it ready to sell (no WAY someone's gettin' my 3.89 locker unless they pry it from my lifeless arms), and I've fried too many clutch LSD's to have a good opinion of them, they're just Mickey Mouse in comparison.
Old 05-03-2005, 07:40 PM
mj_lover's Avatar
expert lurker
thanks for the correction!
1991 5.0L explorer
Old 05-05-2005, 10:06 PM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
a lock uses a manuel locking device such as locking gears or air activated gears that mesh together to turn both axles
posi's use abestos or carbon fiber clutches that put pressure on the spider gears when going forward but the pressure is relieved when turning.
Spools are a replacement for spider gears and both axles turn no matter what not for street use!
Old 05-05-2005, 10:55 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Also wrong on the open differential, MJ. (This isn't your day.) When one is stuck, the other spins in the proper direction. But, with the car on a lift and the transmission in gear, if you turn one forward, the other goes backward.
I had a buddy weld up the spider gears on a '56 Chevy many years ago. While driving it on the street, I could hear the tires chirp as I turned a corner at slow speed and while I parallel parked, but, other than that, I couldn't notice the difference. The right rear no longer went up in smoke at the strip, though.
Old 05-05-2005, 11:04 PM
mj_lover's Avatar
expert lurker
you know, that bad part is, i do know that.....grrr, i feel stupid now...
1991 5.0L explorer
Old 05-06-2005, 02:34 PM
cesar9's Avatar
thank you guys for all the info, now i got it all figure out.
Cesar.
Old 05-08-2005, 05:00 AM
willowbilly3's Avatar
Last journal entry: Body mods
Remember that limited slip is just what it says, limited but not eliminated. I suppose specs are different for different sized units but basically they slip at about 250-275 ft./lbs. of torque when they are new and degenerate with wear. You should do a search on the different types to get a better understanding. In addition to the cheapo limited slips there is the Torsen-Gleason type, the Auburn, the Detroit locker and several others. The T/G is probably one of the toughest and a favorite of off road 4x4 enthusiests. If you plan to run welded/blocked spiders or any kind of spool, then you should put a straight line on your axles and pull them regularly for inspection. I don't want my family in the oncoming lane when you snap an axle.
frame types jkohlbrand Body - Exterior 14 05-08-2005 09:08 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 01:51 PM
types of gm posi's layinitdown Transmission - Rearend 0 06-20-2003 12:39 PM
Anyway of distinguishing metal types? unstable Body - Exterior 5 03-05-2003 04:39 PM
How to ID types of Carb on Tri-Power Set up 66 CT Stang Engine 14 01-29-2003 08:29 PM
